  • VnExperts Networks | Switch quang Cisco 24 port SFP giá rẻ <20 triệu
    Cisco 300 Series Switches
    The Cisco 300 Series, part of the Cisco Small Business line of network solutions, is a portfolio of affordable managed switches that provides a reliable foundation for your business network. These switches deliver the features you need to improve the availability of your critical business applications, protect your sensitive information, and optimize your network bandwidth to deliver information and applications more effectively. Easy to set up and use, the Cisco 300 Series provides the ideal combination of affordability and capabilities for small businesses, and helps you create a more efficient, better-connected workforce.
    The Cisco 300 Series is broad portfolio of fixed-configuration managed Ethernet switches. Models are available with 8 to 48 ports of Fast Ethernet and 10 to 52 ports of Gigabit Ethernet connectivity, providing optimal flexibility to create exactly the right network foundation for your business. However, unlike other small business switching solutions that provide managed network capabilities only in the costliest models, all Cisco 300 Series Switches support the advanced security management capabilities and network features you need to support business-class data, voice, security, and wireless technologies. At the same time, these switches are simple to deploy and configure, allowing you to take advantage of the managed network services your business needs.
    Specifications
    Ports:
    • 26 10/100/1000 ports (SFP)
    • 2 combo mini-GBIC ports
    FLash/Ram: 16/128MB
    VLAN: Support for up to 4096 VLANs simultaneously Port-based and 802.1Q tag-based VLANs MAC-based VLAN
    Throughput: 41.67 Mpps
    Routing/switching capacity: 56 Gbps
    Layer 3:
    IPv4 routing: Wirespeed routing of IPv4 packets Up to 512 static routes and up to 128 IP interfaces
    More information
    VnExperts Networks
    http://vnexperts.vn chuyên phân phối Cisco, Juniper, Fortinet, Peplink...
