Originally posted by gogogo
View Post
Chào !!
hi everyone!!!
today i passed the 640-802 exame
thanks sadikhov.com people.
you help me to achieve the goal
1. material used:
Sybex.CCNA.Cisco.Certified.Network.Associate.Study .Guide.Exam.640-802.6th.Edition
***640-802v3.15
cbtnuggets 822 and 816
2. learning plan:
i read the book, then i saw the cbt and lots of pratice in subnetting.
3. be carrefull only 20% of *** questions were in the cisco exame, my exame had lots of questions with ospf and egirp.
a lab with basic configuration, hostname, passwords, ripv2, etc
nat configuration
it was very hard, and i work with cisco routers and switches evey days.
good luck people for your exames
Chúc vui !!!Trần Mỹ Phúctranmyphuc@hotmail.com
Juniper Certs : JNCIP-ENT & JNCIP-SEC
[version 4.0] Ôn tập CCNA
chào !!!
Hi,
I failed the 640-802 today, I have been studying for about 2-3 months and put quite a bit of time in. I used the Cisco press / Boson to prepare. I also studied the exam cram book. I had around 5 sims, about 2 drag n drops, and the rest were just regular questions. Most of the sims were pretty easy but I got one on EIGRP which I could not figure out and never completed it. I also did bad in the access list / nat area. I checked out the p4's before I took the exam and there were some questions right from the p4's but not many. The p4 that I checked out was version .15. I ended up with a 691, three areas I got 100 percent and other areas I did horrible. I don't recommend the ***, you will learn nothing from them other than memorization. I have a small lab at my home that I use to practice with 7 routers, 2 switches, 1 pix, and 2 aironets. Does anyone have any insight into practicing eigrp, nat, and acls? I would prefer setting them up in my own lab for practice. Is there anywhere out there that has the scenario and the commands that I can sit here and plug them in a few times then try it without plugging them in, then just check my work?
Thanks
Chúc vui !!!!Trần Mỹ Phúctranmyphuc@hotmail.com
Originally posted by fotechvnu View PostMình học CCNA năm ngoái, giờ muốn thi lấy cái chứng chỉ, nge tin này thấy bùn quá :((.
Giờ mình bắt đầu ôn thì nên ôn thế nào ?? Các bạn cho xin ý kiến cái.
Có nên xài bản *** 3.13 và xài nó khôg biết có ăn thua gì không??huhu
Hoc xong ko thi,he' ban
on dc dau thi` on
CISCO doi` trinh` do that
Ok nhe'!
Thi di,nhanh
Đổi nội dung thi CCNA
Originally posted by tranmyphuc1988 View PostChào !!!
Đây có thể xem vừa là tin vui cũng vừa là tin buồn cho networker:
Tin vui :
+++++ Theo như Cisco đã thông báo từ trước sẽ ngày càng siết mạnh cả hình thức thi lẫn đề thi để lọc ra được những người thực sự xứng đáng với các chứng chỉ thi khá phổ biến này.Chính vì thế mà đề thi CCNA (đổi từ ngày 16/8/2008) không chỉ là điểm dừng có là một sự khởi đầu trong việc củng cố lại "giá trị thực của các chứng chỉ cisco"
+++++ Những ai đã từng học CCNA với tinh thần trách nhiệm cao, thái độ tốt nhất và đã từng va chạm nhiều trong quá trình thực hành trong các buổi LAB sẽ thấy sảng khoái với đề thi vì nó thể hiện được đẳng cấp thật của mình.
+++++ Những trung tâm có cán bộ giảng viên tốt , ưu tín sẽ trở thành một lựa chọn hàng đầu của các ứng cử viên thay vì các trung tâm có giá rẻ hơn => Thúc đẩy các trung tâm không ngừng đào tạo đội ngũ giảng viên : Proffessional trong giáo trình, cách dạy, tinh thần trách nhiệm.
Tin buồn :
+++++ Ngoài lệ phí thi khá cao (250$) điểm pass là 825/1000 ,việc đổi đề (hầu như gần hết) đã biến chứng chỉ CCNA thực sự khó khăn để có thể sở hữu. Điều này càng buồn hơn , khi mà đối với những đối tượng sau muốn sở hữu chứng chỉ này :
+++++++++ Người đã từng học khá lâu nhưng chưa kịp thi CCNA ở các trung tâm tin học
+++++++++ Người tự học chưa bao giờ va vấp thiết bị thật.
Chính vì thế mà để có thể giúp ích nhiều cho networker , thiết nghĩ các trung tâm sẽ đưa ra những giải pháp tốt nhất để khắc phục.
Hiện nay theo thông tin được biết ,đề thi CCNA sẽ như sau (xin thông tin để các bạn được rỏ)
+ Tiền thi 250$
+ Điểm pass 825/1000
+ số lượng câu hỏi : thay vì 52 câu bây giờ sẽ là 48 câu (khả năng đậu sẽ càng ít lại)
+ 4/48 câu hỏi là LAB !!!! Bao gồm :
===1) EIGRP , không chỉ đơn giản là cấu hình như trước kia mà bạn cần phải dùng lệnh show và debug để xem xét mới có thể khiến cho cấu hình chạy good : Cisco đưa ra mô hình đã cấu hình sẵn => bạn dùng lệnh debug/show để tìm lỗi sai giúp cho mạng chạy good.(Điều này chỉ có được khi bạn thực hành thường xuyên!!!)
===2) Cấu hình command line interface của Router
===3) Câu lab thứ 3 là về VTP , nhưng mô hình tương tự hình sau :
===4) Mô hình bao gồm 3 Router + 1 switch hoặc 4 router không có switch nào . Nhiệm vụ của bạn là đứng từ một thiết bị và dùng 1 hoặc 2 câu lệnh để có thể đặt ip address với interface tương ứng cho các thiêt bị mà bài LAB yêu cầu.
+ Câu hỏi lí thuyết : đã đổi mới gần như khá nhiều
Như vậy có thể nói rằng :
+ Cisco đã và đang thiên về hướng thực hành nhằm kiểm tra kỹ năng của học viên hơn
+ Hai câu LAB NAt và Frame relay không thấy xuất hiện.
Chúc vui !!!
Thân gửi anh Phúc.
Tôi học CCNA cách đây gần một năm, tôi ở xa trung tâm Đà Nẵng 35KM. Tôi không có thời gian đến trung để luyện thi. Thời gian qua tôi bám vào Te stking_640-802_V13.pdf
là chủ yếu. Tôi đã giải tất cả các câu hỏi của 5 chương NAT, STP, VLAN, WAN, ACCE S S LI ST, và bây giờ đang lở dở với chương Wie r le ss.
Thấy anh gửi nội dung như trên làm tôi rất lo lắng. Liệu mình có lãng phí thời gian hay không, có nên tiếp tục ôn luyện kiểu này. Đây quả thật một câu hỏi giá trị mà tôi không thể trả lời cho chính mình. Với anh là một người hổ trợ tại VNpro, kinh nghiệm, mong anh cho tôi cũng như những ai có hoàn cảnh tương tự một lời khuyên. Thế nào là một cách tự luỵên phù hợp đối với một người không có thời gian đến trung tâm.
Mong chờ anh hồi âm.
Chân thành cám ơn
