This is a sticky topic.
  • IPsec Questions
    Here you will find answers to IPsec Questions
    Question 1
    Internet Protocol Security (IPsec) is a protocol suite for securing Internet Protocol (IP) communications by authenticating and encrypting each IP packet of a data stream. IPsec operation requires which two functions? (Choose two)
    A. using PKI for pre-shared-key authentication
    B. using AH protocols for encryption and authentication
    C. using IKE to negotiate the SA
    D. using Diffie-Hellman to establish a shared-secret key
    Answer: C D
    Question 2
    With which three tasks does the IPS Policies Wizard help you? (Choose three)
    A. Selecting the interface to which the IPS rule will be applied
    B. Selecting the direction of traffic that will be inspected
    C. Selecting the inspection policy that will be applied to the interface
    D. Selecting the Signature Definition File (SDF) that the router will use
    Answer: A B D
    Question 3
    Examine the following options ,when editing global IPS settings, which one determines if the IOS-based IPS feature will drop or permit traffic for a particular IPS signature engine while a new signature for that engine is being compiled?
    A. Enable Engine Fail Closed
    B. Enable Fail Opened
    C. Enable Signature Default
    D. Enable Default IOS Signature
    Answer: A
    Question 4
    Based on the following items, which two types of interfaces are found on all network-based IPS sensors? (Choose two)
    A. Loopback interface
    B. Monitoring interface
    C. Command and control interface
    D. Management interface
    Answer: B C
    Phạm Minh Tuấn
    Yahoo : phamminhtuan_vnpro
    toàn tiếng anh chả hiểu gì cả :| 2/3
    sexlegtøj
    Income Insurance
      bài viết rất có ích, cám ơn b nhé..
        Question 1
        Answer: C D
        Question 2
        Answer: A B D
        Question 3
        Answer: A
        Question 4
        Answer: B C
        Tôi đồng ý, cảm ơn bạn chia sẻ..
