This is a sticky topic.
  • ROUTE (642-902): Drag and Drop Questions
    Question 1
    Drag each item to its proper location
    Place the BGP attributes in the correct order used for determining a route.
    Answer:
    Question 2
    Place the BGP commands to the proper locations
    Answer:
    + show ip bgp: path selection values
    + show ip bgp summary: Memory usage
    + show ip route bgp: AD of BGP
    + show ip bgp neighbor: Notification, update…
    Question 3
    Place the EIGRP commands to the proper locations
    Answer:
    Sources of routes information: show ip eigrp neighbor
    What being learned: show ip eigrp topology
    What actually being used: show ip route eigrp
    Verify eigrp information for each network: show ip interface eigrp
    Question 4
    Place the EIGRP terms to the proper locations
    Answer:
    lists adjacent routers: Neighbor table
    route entries for all destinations: Topology table
    primary route to destination: Successor
    best routers to destinations: Routing table
    backup route to destination: Feasible successor
    Question 5
    Place the EIGRP packets to the proper locations
    Answer:
    Neighbor discovery/recovery mechanism: Hello
    Indicate receipt of any EIGRP packet: Acknowledgement
    Convey reachability of destinations: Update
    Provides specific and reliable information of neighbors: Query
    Instruct the originator not to recompute the route because feasible successors exist: Reply
    Question 6
    Answer:
    Identifies the source of the packet: Router ID
    Identifies the area to which the packet belongs: Area ID
    Contains the authentication type. All OSPF protocol exchanges are authenticated: Authentication Type
    Checks contents of the entire packet for any damage suffered during transmission: Checksum
    Contains authentication information: Authentication
    Contains encapsulated upper-layer information: Data
    Question 7
    Answer:
    Maintains the list of routers connected to the network: Network-LSA
    Describes the collected states of the routers interfaces to an area: Router-LSA
    Describes a route to a destination in another autonomous system: AS-external-LSA
    Describes a route to a destination outside the area: Summary-LSA
    Question 8
    A virtual private network (VPN) is a computer network that is layered on the top of an underlying computer network. VPNs are of different technologies, such as Trusted VPNs, Secure VPNs, and Hybrid VPNs, each having distinct requirements. Drag the various VPN names to their appropriate places.
    Answer:
    All traffic on the VPN must be encrypted and authenticated: Secure VPN
    The routing and addressing used must be established before the VPN is created: Trusted VPN
    The address boundaries must be extremely clear: Hybrid VPN
    Question 9
    IPv6 to IPv4 transition methods
    Answer:
    NAT-PT
    6 to 4 tunnels
    GRE tunnels
    ISATAP tunnels
    Question 10
    IP tunneling is a method to encapsulate IP datagram within IP datagrams, which allows datagrams intended for one IP address to be wrapped and redirected to another IP address. IPv6 packets are encapsulated directly behind the IPv4 header. Drag the header fields to the appropriate places:
    Answer:
    The correct order is:
    IPv4 Header | IPv6 Header | Extension Headers | Upper Layer PDU
    Explanation
    The structure of a normal IPv6 packet is:
    The IPv6 header is always present and is a fixed size of 40 bytes. Zero or more extension headers can be present and are of varying lengths. The upper layer protocol data unit (PDU) usually consists of an upper layer protocol header and its payload (for example, an ICMPv6 message, a UDP message, or a TCP segment).
    Because “IPv6 packets are encapsulated directly behind the IPv4 header” so we can deduce an IPv4 Header must be placed before an IPv6 header.
    Question 11
    Drag each OSPF states into correct definition.
    Answer and Explanation
    The OSPF states below are described in the correct order when OSPF adjacency is formed:
    Down: No information has been received, but Hello packets can still be sent to the neighbor
    Init: A Hello packet is received, but the ID of the receiving router was not included in the Hello packet.
    2-way: Each router see its own Router ID in the neighbor field of the Hello packet; there is a DR/BDR election.
    Exstart: The routers and their DR and BDR establish a master-slave relationship.
    Exchange: Routers exchange DBD packets that describe the contents of the entire link-state database.
    Loading: Based on the information provided by the DBDs, routers send link-state request packets
    Full: All the router and network LSAs are exchanged and the router databases are synchronized
    A detailed explanation of OSPF states can be found here: http://www.cisco.com/c/en/us/support.../13685-13.html.
    Question 12
    Drag the “show” commands on the left to their proper locations on the right.
    Answer:
    + show ip route eigrp: show EIGRP routing tables in routing table / confirm what is actually being used / does routing
    + show ip eigrp interface: show information about interface configured for EIGRP / Verify the routing of specific interface /
    show what being used
    + show ip eigrp traffic: show the number of EIGRP packets sent and received
    + show ip eigrp neighbors: Displays the neighbor discovered by EIGRP. Show what is learned
    + show ip eigrp topology: shows the routes known to a router’s EIGRP routing process. Confirm what EIGRP Learning show what does it learned
    Question 13
    LSA corresponding area type.
    Answer:
    + stub: LSA 1,2,3
    + NSSA: LSA 1,2,3,7
    + Backbone or transit: LSA 1,2,3,4,5
    + Totally NSSA: LSA 1,2,7
    + Totally stubby: LSA 1,2
    Question 14
    Answer:
    + MED: Propagated between AS
    + weight: Propagated within local preference / used with multiple exit points out of an AS
    + Local Preference: Propagated within AS
    Question 15
    Answer:
    + Bandwidth Management: low-speed WAN links
    + Authentication: WAN link to an external supplier
    + Redistribution: integrating two merging companies
    + Stubs: 256 kb/s CIR FR hub and spokes
    Question 16
    Click the resources on the left that you need to create an implementation plan for an OSPF project and drag them to the target zone on the right.
    Answer:
    + Summarization boundaries
    + OSPF process ID that will be used
    + Authentication type that will be used
    + OSPF area and associated prefix
    Question 17
    Answer:
    + Which is used by router if route has more than one exit: weight
    + Which is not propagated in updates: weight
    + Which is spread through in the AS: local preference
    + Which goes to other AS: MED
    Question 18
    Click and drag the BGP attribute characterization on the left to the correct BGP attribute on the right.
    Answer:
    MED Attribute is propagated between autonomous systems
    Local Preference Attribute is propagated throughout the local autonomous system
    Weight Attribute + is not advertised to neighboring routers
    + used for one router with multiple exit points out of the autonomous system
