This is a sticky topic.
  • CCDA: Network Management
    Question 1
    What are three valid methods of gathering information about an existing data network? (Choose three)
    A. Use organizational input.
    B. Perform a traffic analysis.
    C. Analyze the user-mapping of a running application.
    D. Perform a packet-level audit to verify carrier service guarantees.
    E. Perform a network audit to gather more detail about the network.
    F. Use reports that analyze the metrics of the customer’s existing network.
    Answer: A B E
    Question 2
    Which of the following Cisco router services performs network traffic analysis to assist in documenting a customer’s existing network?
    A. MRTG
    B. NetMon
    C. NetFlow
    D. SNMP MIB compiler
    Answer: C
    Question 3
    You are performing an audit of a customer’s existing network and need to obtain the following router information:
    interfaces
    running processes
    IOS image being executed
    Which command should you use?
    A. show version
    B. show tech-support
    C. show startup-config
    D. show running-config
    E. show processes memory
    Answer: B
    Question 4
    Which Cisco device management feature is most suited to metering network traffic and providing data for billing network usage?
    A. BGP
    B. Cisco Discovery Protocol
    C. QoS
    D. RMON
    E. NetFlow
    Answer: E
    Question 5
    Which network management protocol allows a network device to have vendor-specific objects for management?
    A. SNMPv1
    B. SNMP v2
    C. SNMP v3
    D. MIB
    E. RMON1
    F. RMON2
    Answer: D
    Question 6
    Which three sources does a network designer use to collect information for characterizing an existing network? (Choose three)
    A. staff input
    B. visual inventory
    C. network audit
    D. traffic analysis
    E. server statistics
    Answer: A C D
