This is a sticky topic.
  • CCDA: EIGRP Questions
    Question 1
    Which two of these are the most accurate characteristics of EIGRP deployment? (Choose two)
    A. Provides features for most Ethernet, Frame Relay, and dial-up network deployment types.
    B. Provides routing for IPv4, IPv6, Appletalk, and IPX.
    C. Provides default hierarchical routing and summarization of a VLSM IP address deployment.
    D. Provides quick convergence through neighbor relationships and topology backup routes.
    E. Provides the best route selection on combined default metrics of active bandwidth,delay, load, reliability, and MTU parameters.
    Answer: B D
    Question 2
    Your company’s Cisco routers are operating with EIGRP. You need to join networks with an acquisition’s heterogeneous routers at 3 sites, operating with EIGRP and OSPF. Which describes the best practice for routing protocol deployment?
    A. apply OSPF throughout both networks
    B. apply one-way redistribution exclusively at each location
    C. apply two-way redistribution exclusively at each location
    D. apply two-way redistribution at each location with a route filter at only one location
    E. apply two-way redistribution at each location with a route filter at each location
    F. apply EIGRP with the same autonomous system throughout both networks
    Answer: E
    Question 3
    A network is being designed to meet the requirements listed. Within the enterprise network:
    All routers are Cisco 3800 Series routers running the latest Cisco IOS release.
    The fastest convergence time possible is required.
    Unequal cost load-balancing is required.
    For Internet connections:
    A single link is used to connect to a single ISP.
    Which two routing protocols should be used?(Choose two)
    A. Use OSPF as the IGP within the enterprise.
    B. Use EIGRP as the IGP within the enterprise.
    C. Use Internal BGP as the IGP within the enterprise.
    D. Use External BGP between the enterprise and the ISP.
    E. Use EIGRP between the enterprise and the ISP.
    F. Use Static (Default) routing between the enterprise and the ISP.
    Answer: B F
    Question 4
    Which two statements best describe intradomain route summarization? (Choose two)
    A. OSPF and RIP automatically summarize at classful network boundaries.
    B. EIGRP and OSPF automatically summarize at classful network boundaries.
    C. EIGRP and RIP automatically summarize at classful network boundaries.
    D. EIGRP and OSPF must be manually configured to summarize at non-classful boundaries.
    E. EIGRP and OSPF automatically summarize at non-classful boundaries.
    Answer: C D
