This is a sticky topic.
  • CCDA: Other Routing Protocols
    Question 1
    Which of these is the best routing deployment for a single dedicated link to an ISP for Internet access?
    A. EIGRP
    B. RIP
    C. BGP
    D. Static
    Answer: D
    Question 2
    Which two routing protocols operate over NBMA point-to-multipoint networks without the use of point-to-point subinterfaces? (Choose two)
    A. RIPv1
    B. RIPv2
    C. IGRP
    D. EIGRP
    E. OSPF
    F. IS-IS
    Answer: D E
    Question 3
    For which network scenario is static routing most appropriate?
    A. parallel WAN links
    B. IPSec VPN
    C. expanding networks
    D. hierarchical routing
    Answer: B
    Question 4
    Your company uses OSPF for internal routing. The company will be connected to VendorA via a single dedicated link and to VendorB via redundant dedicated links. Both vendors also use OSPF for internal routing. Which of the following deployments describes the best intra-domain routing practice in this situation?
    A. Connect your company to both VendorA and VendorB using existing OSPF.
    B. Redistribute the routes on each link between your company and the vendors to a shared EIGRP routing protocol.
    C. Use IBGP to reach VendorA and EBGP to reach VendorB.
    D. Use static routes to reach VendorA and EBGP to reach VendorB.
    E. Use static routes to reach both VendorA and VendorB.
    Answer: D
