bạn nào có crack của boson netsim 7.0 thì share cho tôi với, thank rất nhiều
bạn chịu cực download ở đây:
Code:http://rs88.rapidshare.com/files/57952078/the.boson.netsim.v.7.02.incl.crack.rar
Boson 7.02 - Đây là file .torrent
Sau khi tải về và làm theo hướng dẫn thì cứ dùng bình thường, chú ý là khi Updates thì đừng có tải file Boson_NetSim.exe về, chịu khó dùng bản này chắc cũng đủ rồi.
hxxp://rapidshare.com/files/66566459/ccnp_netsim7.exe
Installation instruction :
1) Download boson CCNP netsim7 from www.boson.com (it is 7.02 version)
2) install it, file name is 'ccnp_netsim7.exe'
3) open netsim7, click on 'Use demo version' and then update it. it will become 7.04 version. it is still demo version.
we can not configure router, pc etc in demo mode. that is if u use 'configure terminal' command,
it will not be execute.
[how to update manually(this for those who don't have net in home):
updater only change this file (i) Boson_NetSim.exe (ii)LabCompiler.exe (iii)version.ini . so copy this file from other
updated ccnp netsim7.04 from other PC to your PC in 'D:\Program Files\Boson Software\Boson NetSim for CCNP 7.0' ]
4) Close netsim7
5) replace 'D:\Documents and Settings\All Users\Application Data\Boson Software\Boson NetSim for CCNP
7.0\mscon43demo.dll'[this file is hidden so go to 'tool' menu then 'folder option' do appropriate action in 'my computer'
window] with this cracked 'http://rapidshare.com/files/66566624/mscon43demo.dll'
6) Still you have to click on 'use demo version' but u can now use all command
Copy & overwrite existing mscon43demo.dll to:
Vista------- \ProgramData\Boson Software\Boson NetSim for CCNP 7.0\
XP --------- \Documents and Settings\All Users\Application Data\Boson Software\Boson NetSim 7
from sadikhov
tớ vừa download bản boson 7.02, cài file mscon43demo.dll.
Khi config cai Switch or Router gặp error vậy nè...:)
Switch(config)#hostname IPS
% Invalid input detected at '^' marker.
Lỗi này là do phần mềm Boson Netsim. Câu lệnh của bạn dùng để gán tên cho một router như vậy là hoàn toàn đúng.Đặng Quang Minh, CCIE#11897 (Enterprise Infrastructure, Wireless, Automation, AI), CCSI#31417
Tớ cũng gặp lỗi này , khi vào mode Config chỉ thực hiện được mỗi lệnh exit . Có cao nhân nào chỉ bảo giúp với , đang cần lắm rồi .Originally posted by Ciscoguy View Posttớ vừa download bản boson 7.02, cài file mscon43demo.dll.
