  • Help Khắc phục lỗi trong dynagen !!
    khi chạy file.net, thì dynamip server báo lỗi này, đã bác nào gặp trường hợp này chưa ?
    File net .
    # Another simple dynagen configuration file
    # All the f0/0 interfaces are on VLAN 1 and the F1/0 interfaces are on VLAN 2
    [localhost]
    [[7200]]
    image = \Program Files\Dynamips\images\c3640-io3-mz.122-32_extract.bin
    # On Linux / Unix use forward slashes:
    ram = 160
    mmap = True
    [[ROUTER R1]]
    console = 2001
    f0/0 = LAN 1
    f1/0 = LAN 2
    [[ROUTER R2]]
    console = 2002
    f0/0 = LAN 1
    f1/0 = LAN 2
    [[ROUTER R3]]
    console = 2003
    f0/0 = LAN 1
    Day la lỗi trên dynamip server. khi chạy file .net
    Cisco Router Simulation Platform (version 0.2.7-x86)
    Copyright (c) 2005-2007 Christophe Fillot.
    Build date: May 29 2007 09:03:26
    ILT: loaded table "mips64j" from cache.
    ILT: loaded table "mips64e" from cache.
    ILT: loaded table "ppc32j" from cache.
    ILT: loaded table "ppc32e" from cache.
    Hypervisor TCP control server started (port 7200).
    Shutdown in progress...
    Shutdown completed.
    CPU0: carved JIT exec zone of 16 Mb into 512 pages of 32 Kb.
    C7200 instance 'R1' (id 0):
    VM Status : 0
    RAM size : 160 Mb
    IOMEM size : 0 Mb
    NVRAM size : 128 Kb
    NPE model : npe-200
    Midplane : vxr
    IOS image : \Program Files\Dynamips\images\c3640-io3-mz.122-32_extract.bin
    Loading ELF file '\Program Files\Dynamips\images\c3640-io3-mz.122-32_extract.bin
    ELF entry point: 0x80008000
    C7200 'R1': starting simulation (CPU0 PC=0xffffffffbfc00000), JIT enabled.
    % No memory map for code execution at 0x0
    % Unable to create instruction block for vaddr=0x0
    insn_page_compile: unable to create JIT block.
    VM 'R1': unable to compile block for CPU0 PC=0x0
    C7200 instance 'R2' (id 1):
    VM Status : 0
    RAM size : 160 Mb
    IOMEM size : 0 Mb
    NVRAM size : 128 Kb
    NPE model : npe-200
    Midplane : vxr
    C7200 'R2': starting simulation (CPU0 PC=0xffffffffbfc00000), JIT enabled.
    C7200 instance 'R3' (id 2):
    VM Status : 0
    RAM size : 160 Mb
    IOMEM size : 0 Mb
    NVRAM size : 128 Kb
    NPE model : npe-200
    Midplane : vxr
    VM 'R2': unable to compile block for CPU0 PC=0x0
    File net .
    [localhost]
    [[7200]]
    ram = 160
    mmap = True
    [[ROUTER R1]]
    console = 2001
    f0/0 = LAN 1
    f1/0 = LAN 2
    [[ROUTER R2]]
    console = 2002
    f0/0 = LAN 1
    f1/0 = LAN 2
    [[ROUTER R3]]
    console = 2003
    f0/0 = LAN 1
    Shutdown completed.
    VM Status : 0
    RAM size : 160 Mb
    IOMEM size : 0 Mb
    NVRAM size : 128 Kb
    NPE model : npe-200
    Midplane : vxr
    VM Status : 0
    RAM size : 160 Mb
    IOMEM size : 0 Mb
    NVRAM size : 128 Kb
    NPE model : npe-200
    Midplane : vxr
    VM Status : 0
    RAM size : 160 Mb
    IOMEM size : 0 Mb
    NVRAM size : 128 Kb
    NPE model : npe-200
    Midplane : vxr
    hi
    [[7200]] => [[3640]]
    ram = 160
    mmap = True
    Chúc bạn vui !!!
    Trần Mỹ Phúc
    tranmyphuc@hotmail.com
    Juniper Certs :
    JNCIP-ENT & JNCIP-SEC
    [version 4.0] Ôn tập CCNA
      [localhost]
      [[7200]]
      ram = 160
      mmap = True
      [[ROUTER R1]]
      console = 2001
      f0/0 = LAN 1
      f1/0 = LAN 2
      [[ROUTER R2]]
      console = 2002
      f0/0 = LAN 1
      f1/0 = LAN 2
      [[ROUTER R3]]
      console = 2003
      f0/0 = LAN 1
      image = C:\Program Files\Dynamips\images\c3640-io3-mz.122-32_extract.bin
      [[7200]] ==> [[3640]]
      trên mỗi router, thêm:
      model = 3640
      :32::53::X:106:
      Nothing last forever...
        thanks nhé !
          Originally posted by trainingit View Post
          [localhost]
          [[7200]]
          ram = 160
          mmap = True
          [[ROUTER R1]]
          console = 2001
          f0/0 = LAN 1
          f1/0 = LAN 2
          [[ROUTER R2]]
          console = 2002
          f0/0 = LAN 1
          f1/0 = LAN 2
          [[ROUTER R3]]
          console = 2003
          f0/0 = LAN 1
          model = 3640
          Bạn chỉ rõ duoc ko? mình đổi 7200 thành 3640 thi báo lỗi :
          router Zapp does not have IOS image name set
          model = 3640 đặt ở chổ nào vậy?
          THanks
            THanks
            - bạn đặt
            model = 3640
            ở ngay dưới dòng khai báo của các router, vd:
            [[Router R1]]
            model = 3640
            tất cả các router, ngoại trừ IOS 7200, thì đều phải khai báo model.
            :32::53::X:106:
              Cám ơn đã trả lời nhanh.
              Nhưng mình vẫn chưa chạy duoc.
              Mình khai báo lại rồi, nhưng khi chạy file .net nó báo lỗi
              *** Warning: Starting Zapp with no idle-pc value
              Bạn biết lỗi này ko?
                Chào !!!
                Đây không phải lỗi mà là câu thông báo là bạn chưa set giá trị idlepc cho router Zapp. Giá trị này giúp giảm tốc độ xử lí của CPU lại .
                Bạn set như sau :
                dùng lệnh : idlepc get Zapp
                roi doi 1 khoảng thơi gian nó sẽ hiện ra 10 giá trị tương ứng là 10 dòng. Khuyến cáo,: bạn chọn dòng nào có * ở đầu. Nếu lần 1 ko tìm thấy thì bạn tiếp tục đánh câu lệnh trên lần 2.
                Chúc bạn vui !!!
                Trần Mỹ Phúc
                Juniper Certs :
                  - đây chỉ là cảnh báo bt, chưa set giá trị idlepc,
                  - dùng lệnh sau để ktra:
                  =>list
                  sau khi đã có danh sách các thiết bị chạy trong lab, bạn có thể dùng
                  =>idlepc get device-name
                  để có giá trị idlepc, dấu * có nghĩa là bạn có thể dùng giá trị này làm giảm năng lực xử lý của CPU cho lab, bạn chỉ cần nhập đúng số thứ tự cho giá trị đó và Enter --> giá trị đó sẽ được apply, hoặc có thể dùng giá trị đó khai báo vào trong file .net , khi khai báo trong file .net nhớ bỏ hết ffffffffff
                  vd,
                  [[Router R1]]
                  model = 3640
                  console = 2000
                  idlepc = 0x605b99d4 # bỏ hết ffffffffff từ giá trị mà
                  ----------------------# bạn lấy từ idle get R1
                  :32::53::X:106:
                    Cám ơn bạn nhiều.
                    Cho hỏi thêm nếu muốn tự mình làm sơ đồ mạng thì phải làm thế nào, có luật định sẵn để tạo file .net, những luật đó tham khảo ở đâu?
                    ví dụ: slot1 = NM-16ESW, f0/0 = LAN 1,... hiểu được ntn
                    Many Thank
                      Cám ơn bạn nhiều.
                      Many Thank
                      xem qua link này nhé:
                      - bạn cứ hình dung file .net giống như là một tờ giấy trắng, sau đó bạn vẽ sơ đồ lên đó (nhưng các kêt
                      nối thể hiện bằng text, và hơi trìu tượng), đầu tiên nếu chưa thiết lập được file .net thì bạn có thể
                      vẽ qua topo, rồi từ đó dễ lập mô hình hơn.
                      :32::53::X:106:
                        Chào !!
                        Thật sự chủ đề bạn nêu có rất nhiều trong forum này, bạn chịu khó search đi.
                        chúc thành công !
