  • How to use extended-range vlans in the NM-16ESW
    In case that you don't already know, in the latest IOS (> 12.4(15)T) you can use extended-range vlans (1006-4094) in your dynamips router/switch (using the NM-16ESW module). Also the vlan database mode is not recommended anymore and you can use the latest config-vlan submode. That way you can replicate more closely the various vendor labs.
    I'm using a 3725 as switch, so this is its config in the net file:
     [[3725]]
      image = /usr/share/cisco-ios/c3725-adventerprisek9-mz.124-15.T5.extracted.bin
      ram = 148
      disk0 = 8
      disk1 = 0
      # The idlepc value hasn't been tested extensively, so it might not work in your case.
      idlepc = 0x6148b594
    The tricky part is that you don't get any indication of this capability; it's like a hidden command. But if you try to configure it, it'll be accepted and it'll work fine.
    SW1#conf t
    Enter configuration commands, one per line.  End with CNTL/Z.
    SW1(config)#vlan ?
      accounting  VLAN accounting configuration
      ifdescr     VLAN subinterface ifDescr
    SW1(config)#vlan 2567
    SW1(config-vlan)#name VLAN-2567
    SW1(config-vlan)#^Z
    SW1#
    Configure this vlan under an interface:
    SW1#conf t
    SW1(config)#int f1/1
    SW1(config-if)#switchport access vlan ?
      <1-4094>  VLAN ID of the VLAN when this port is in access mode
    SW1(config-if)#switchport access vlan 2567
    SW1(config-if)#^Z
    SW1
    Verify the vlan:
    SW1#sh vlan-sw br
    VLAN Name                             Status    Ports
    1    default                          active    Fa1/0, Fa1/4, Fa1/5, Fa1/6
                                                    Fa1/7, Fa1/8, Fa1/9, Fa1/10
                                                    Fa1/11, Fa1/12, Fa1/13, Fa1/14
                                                    Fa1/15
    13   VLAN0013                         active
    1002 fddi-default                     act/unsup
    1003 token-ring-default               act/unsup
    1004 fddinet-default                  act/unsup
    1005 trnet-default                    act/unsup
    2567 VLAN-2567                        active    Fa1/1
    Verify the spanning-tree:
    SW1#sh spanning-tree vlan 2567
     VLAN2567 is executing the ieee compatible Spanning Tree protocol
      Bridge Identifier has priority 32768, address c200.04f8.0001
      Configured hello time 2, max age 20, forward delay 15
      We are the root of the spanning tree
      Topology change flag set, detected flag set
      Number of topology changes 2 last change occurred 00:00:19 ago
              from FastEthernet1/2
      Times:  hold 1, topology change 35, notification 2
              hello 2, max age 20, forward delay 15
      Timers: hello 1, topology change 16, notification 0, aging 300
     Port 42 (FastEthernet1/1) of VLAN2567 is forwarding
       Port path cost 19, Port priority 128, Port Identifier 128.42.
       Designated root has priority 32768, address c200.04f8.0001
       Designated bridge has priority 32768, address c200.04f8.0001
       Designated port id is 128.42, designated path cost 0
       Timers: message age 0, forward delay 0, hold 0
       Number of transitions to forwarding state: 1
       BPDU: sent 193, received 0
    Extended-range VLANs are not saved in the VLAN database; they are saved in the switch that runs the configuration file.
    SW1#sh run | b vtp
    vtp mode transparent
    vlan 2567
     name VLAN-2567
    If you get the following message while trying to configure the vlan under an interface, try to shut the interface, reenter the vlan and then unshut the interface:
    SW1#conf t
    % Warning: port will be inactive in non-ethernet VLAN
    SW1(config-if)#^Z
    SW1#sh int f1/1 switchport
    Switchport: Enabled
    Administrative Mode: static access
    Operational Mode: static access
    Administrative Trunking Encapsulation: dot1q
    Operational Trunking Encapsulation: native
    Negotiation of Trunking: Disabled
    Access Mode VLAN: 2567 ((Inactive))
    Trunking Native Mode VLAN: 1 (default)
    Trunking VLANs Enabled: ALL
    Trunking VLANs Active: 2567
    Protected: false
    Priority for untagged frames: 0
    Override vlan tag priority: FALSE
    Voice VLAN: none
    Appliance trust: none
    SW1#conf t
    SW1(config-if)#shut
    SW1(config-if)#no switchport access vlan 2567
    SW1(config-if)#no shut
    SW1(config-if)#^Z
    Switchport: Enabled
    Access Mode VLAN: 2567 (VLAN-2567)
    Protected: false
    Voice VLAN: none
    Also, as you may already know, vtp must be in transparent mode if you want to configure extended-range vlans:
    SW1#sh vtp status
    VTP Version                     : 2
    Configuration Revision          : 0
    Maximum VLANs supported locally : 36
    Number of existing VLANs        : 6
    VTP Operating Mode              : Server
    VTP Domain Name                 :
    VTP Pruning Mode                : Disabled
    VTP V2 Mode                     : Disabled
    VTP Traps Generation            : Disabled
    MD5 digest                      : 0xF5 0xBA 0x45 0x80 0xA7 0x6B 0x76 0x88
    Configuration last modified by 0.0.0.0 at 3-1-02 00:07:07
    Local updater ID is 0.0.0.0 (no valid interface found)
    SW1#conf t
    SW1(config-vlan)#exit
    % Failed to create VLANs 2567
    Extended VLAN(s) not allowed in current VTP mode.
    %Failed to commit extended VLAN(s) changes.
    SW1(config)#
    *Mar  1 00:02:23.247: %SW_VLAN-4-VLAN_CREATE_FAIL: Failed to create VLANs 2567: extended VLAN(s) not allowed in current VTP mode
    If you get the following error while trying to change vtp mode, you can erase and then squeeze the flash in order to fix it:
    SW1#conf t
    SW1(config)#vtp mode server
    Setting device to VTP SERVER mode
    % not enough space on flash to store vlan database. trying squeeze...
    squeeze in progress...
    % error squeezing flash - (Unknown error 0)
    SW1#squeeze flash:
    Squeeze operation may take a while. Continue? [confirm]
    %Error squeezing flash (Unknown error 0)
    SW1#erase flash:
    Erasing the flash filesystem will remove all files! Continue? [confirm]
    Erasing device...  ...NOT erased
    Erase of flash: complete
    SW1#squeeze flash:
    Squeeze of flash complete
    Trần Mỹ Phúc
    tranmyphuc@hotmail.com
    Juniper Certs :
    JNCIP-ENT & JNCIP-SEC
    [version 4.0] Ôn tập CCNA
