  • 3725 on dynamips against 3550/3560 and what is missing
    Chào,
    Dưới đây là những cái mà Switch giả lập chưa thể làm được trong bài test CCIE R&S
    Access Switch Device Manager (SDM) Template
    ACL - Improved Merging Algorithm
    ARP Optimization
    BGP Increased Support of Numbered as-path Access Lists to 500
    BGP Restart Neighbor Session After max-prefix Limit Reached
    BGP Route-Map Continue Support for Outbound Policy
    Clear Counters Per Port
    DHCP Snooping
    DHCP Snooping Counters
    Diagnotics Options on bootup
    ErrDisable Reactivation Per Port
    ErrDisable timeout
    EtherChannel
    EtherChannel - Flexible PAgP
    Etherchannel Guard
    Fallback Bridging
    Flex Link Bi-directional Fast Convergence
    Flex Link VLAN Load-Balancing
    Flex Links Interface Preemption
    GOLD - Generic Online Diagnostics
    IEEE 802.1ab, Link Layer Discovery Protocol
    IEEE 802.1s - Multiple Spanning Tree (MST) Standard Compliance
    IEEE 802.1s VLAN Multiple Spanning Trees
    IEEE 802.1t
    IEEE 802.1W Spanning Tree Rapid Reconfiguration
    IEEE 802.1x - Auth Fail Open
    IEEE 802.1x - Auth Fail VLAN
    IEEE 802.1x - VLAN Assignment
    IEEE 802.1x - Wake on LAN Support
    IEEE 802.1x Authenticator
    IEEE 802.1X Multi-Domain Authentication
    IEEE 802.1x RADIUS Accounting
    IEEE 802.1x with Port Security
    IEEE 802.3ad Link Aggregation (LACP)
    IEEE 802.3af Power over Ethernet
    IGMP Fast Leave
    IGMP Version 1
    IGRP
    IP Phone Detection Enhancements
    IP Phone Enhancement - PHY Loop Detection
    IPSG (IP Source Guard)
    Jumbo Frames
    L2PT - Layer 2 Protocol Tunneling
    MAC Authentication Bypass
    MLD Snooping
    Multicast Etherchannel Load Balancing
    NAC - L2 IEEE 802.1x
    NAC - L2 IP
    NAC - L2 IP with Auth Fail Open
    Packet-Based Storm Control
    Per Port Per VLAN Policing
    Port Security
    Port Security on Private VLAN Ports
    Private VLANs
    QoS Policy Propagation via Border Gateway Protocol (QPPB)
    Rapid-Per-VLAN-Spanning Tree (Rapid-PVST)
    Reduced MAC Address Usage
    Remote SPAN (RSPAN)
    Smart Port
    Spanning Tree Protocol (STP) - Loop Guard
    Spanning Tree Protocol (STP) - Portfast
    Spanning Tree Protocol (STP) - PortFast BPDU Filtering
    Spanning Tree Protocol (STP) - Portfast Support for Trunks
    Spanning Tree Protocol (STP) - Root Guard
    Spanning Tree Protocol (STP) - Uplink Load Balancing
    SRR (Shaped Round Robin)
    Standby Supervisor Port Usage
    STP Syslog Messages
    Switching Database Manager (SDM)
    Trunk Failover
    Trusted boundary (extended trust for CDP devices)
    Unicast Mac Filtering
    UniDirectional Link Detection (UDLD)
    VLAN Access Control List (VACL)
    VLAN Aware Port Security
    Weighted Tail Drop (WTD)
    Chúc vui vẻ.
    Trần Mỹ Phúc
    tranmyphuc@hotmail.com
    Juniper Certs :
    JNCIP-ENT & JNCIP-SEC
    [version 4.0] Ôn tập CCNA
