  • Hướng dẫn cách cài phần mềm Qemu mô phỏng ASA
    Contents
    STEP 1: Download ASA.zip for Windows
    STEP 2: Create Windows Lookbacks
    STEP 3: Get the NIO_gen_eth:\Device\NPF_{......................... ...........}
    STEP 4: Modify the ASA.bat
    STEP 5: Launching ASA.bat
    STEP 6: Telnet to localhost 1234
    STEP 7: Launching ASDM
    STEP 1: Download ASA.zip for Windows and extract asa.zip
    STEP 2: Create Windows Lookbacks Interfaces
    Next double click the network device list.cmd link created when you installed Dynamips
    Copy the list of all your loopbacks to a text file for use in the next step
    @echo off
    cls
    title ASA Simulator
    setlocal
    set command_name= qemupcap -L . -hda FLASH1 -hdachs 980,16,32 -kernel vmlinuz -initrd asa.gz -m 256 --no-kqemu
    set parameter= -append "auto nousb ide1=noprobe bigphysarea=16384 console=ttyS0,9600n8 hda=980,16,32"
    set nic1=-net nic,vlan=0,model=i82557b,macaddr=00:aa:00:00:02:01 -net pcap,vlan=0,ifname=
    \Device\NPF_{3FA53BEB-D3A0-45C2-88E4-1C10A303A04C}
    set nic2=-net nic,vlan=1,model=i82557b,macaddr=00:aa:00:00:02:02 -net pcap,vlan=1,ifname=
    \Device\NPF_{F9805ACA-752F-4373-A62D-057A8F9EE24E}
    set options=-serial telnet::1234,server,nowait
    %command_name% %parameter% %nic1% %nic2% %options%
    Set ip address for ASA to ping ip address of TFTP server
    Press Button : Run Startup Wizard
    Press YES
    Enter username and password
    Đặng Hoàng Khánh
    Ko thấy link đâu bạn Khánh , upload lên http://www.mediafire.com/ hen ... Hấp dẫn quá !
    khungbo33 - destination unreachable .....!
      khủng bố vào đây down IOS cho ASA nhé :
      :32::53::X:106:
      Nothing last forever...
        to trainingit: ko phải link asa mà nguyên cái link của dangkhoangkhanh cơ :D , đã cài freebsd có asa luôn , config luôn chỉ cần extract ra là xong ... :D
        thanks mọi người !
          "Use Google before asking dumb questions" vẫn đúng :D
          Link: http://www.4shared.com/file/42737514/9de0d8c4/asa.html
          Đang kiểm tra thử có chạy được hok ?
          Thanks mọi người !
            để chạy thì khungbo dùng cái file image trong link này:
            http://www.4shared.com/file/46879170/db9854b2/asa.html?
              "Your ASA image has a version number 8.0(2) which is not supported by ASDM 6.1(1)"
              Tested ! :((
              Theo dõi topic của tác giả tại đây:
                xin chao cac pro
                Pro nao co phan mem qemu lam on up len dien forum de anh em down ve tham khao voi.
                xin cam on!
                  Hi anh Khánh,
                  Anh cho hỏi làm sao để kết nối được ASA giả lập với router trong dynamip?
                  Dùng phần mềm qemu trên với OS linux nào (Centos, ubuntu, redhat..)để chạy được ASA vậy anh?
                  Thân mến.
                    Tested ! :((
                    Mình cũng gặp phải lỗi này!!! Phải làm sao đây các anh????
                      Minh cung gap loi nay, co ai biet cach fix loi nay ko chi cho minh voi!
                        Hiihiiiiiiiiiiiiiiiiiiii
                          mhpit dung thu cai adsm 6.0(2)
                            thu dung cai asdm 6.0(2) xem sao
                              xin hoi step 3 cua DangHoangKhanh thi lam sao vay ? Thanks.
